SO35 keel to hull joint
Jun 25, 2011 10:10:28 GMT
Post by gaj on Jun 25, 2011 10:10:28 GMT
Are there any forumites out there who either own a Jeanneau SO35 circa 2005 with a 1.85mt draught or can readily see one on the hard that could have a quick look at the closeness of the fit of the keel to hull joint and report back?
The reason being that my oldest pal is now the proud new owner of such a vessel (sold up and life savings just gone into the purchase) and has been dismayed to find a crack in the keel to hull joint at the fwd end upon lifting out the day before yesterday. In an attempt to calm him I pointed out that this is not uncommon with boats of this type of construction due to some minor flexing of the hull when the weight is placed upon the keel root and the hull particularly if the propping is not adequate. I know the yard where the boat is and have no doubt that the cradle and propping is spot on. Unforunately further investigation has shown that the gap between the top of the keel and the hull is approximately 10mm at the fwd end, tapering off aft. This space was filled with sealant and covered with antifouling. I would have hoped for no gap at all but not be uduly concerened by say 2mm or a little more but 10mm does not look good.
The question is did it come out of the factory like that due to the mating surfaces of the hull and keel not being matching profiles and that all the SO35's are the same? If that is the case it is a manufacturing issue and there will be little to be done about that I guess. I imagine then the answer is to clean out the old sealant, clean the stud/bolt etc and rebed and tighten all the keel bolts to the required torque setting.
On the other hand it could be something more serious that was missed during the pre purchase survey carried out a few weeks ago?
No grounding since taking possession of the boat.
Any first hand observations would be really be most helpful.
