gipsy4
Sun Odyssey 43 DS
Post by gipsy4 on May 31, 2011 13:24:52 GMT
I have got a problem with a corroded water lock on my SO 43 DS. In order to get it out, you have to remove the Diesel tank. I once did this already and had the part welded, but now water is coming out again.
As I assume, the problem lies in the wrong stainless steel, which once was used for the water lock. I am not sure, whether it is wise, to order a new one from Jeanneau, which is possible for a lot of money. Likely the same problem will occur then later.
Now I am looking for alternative solutions, e.g. installing a different lock under the beds. However, space is very limited there. Anybody has experience with this problem? Any answers welcome
thanks, Ronald
Post by exitstrategy on Oct 9, 2013 23:26:32 GMT
We have the same problem with our 2002 SO43DS and will either replace with original or repair what have others done? I will finish removing tomorrow, not a fun job especially getting the flange off the muffler so it can be removed.
Thanks, Dave
