whitebird
2003 Sun Odyessy 35
Post by whitebird on May 16, 2011 11:20:23 GMT
I recently tried to install a nice set of Garhauer adjustable jib lead cars on our SO 35. Immediately I found a problem. Jeanneau never bolted down the last 8 inches on the aft end of both tracks. This allowed the ends to bend up if the cars were used all the way aft. This put a kink in the track so that the new cars would not slide into place. It was solved by removing the 50 bolts , taking off each track and straightening. I then drilled another hole at the end of each track and installed a new bolt to hold the ends down. All in all this is a project that should not have had to be done. I am not sure if this affected only our boat or every one. This might be something to look at on all models
Deleted
Deleted Member
Post by Deleted on May 16, 2011 14:50:07 GMT
Our 2003 SO35 had the same issue.
Post by Full Circle on May 16, 2011 21:59:38 GMT
Thanks for the heads up, I will make sure |I sort that issue before trying to distort my tracks.
