haven
Post by haven on Apr 18, 2011 2:01:33 GMT
I just bought a 39i and I won't be at the boat for a couple of weeks. Looking for cookware to send to the boat. It has a two burner ENO stove, but i have no idea what size pans will fit. If you happen to be reading this and near the same stove, could you measure the radius from the center of each burner to the nearest obstruction (side/front/rear)?
*IF* the diagram I have is right, it looks like the radius is only 4.5", so 9" pan is max max... could that be right?!?!
Deleted
Deleted Member
Post by Deleted on Apr 20, 2011 20:42:46 GMT
9" pan is about right. Our ENO (Gascogne, I believe) cooker top measures 500 X 330mm. Radius from hob centre - fore & aft - 135mm (5 1/4") Radius from hob centre - athwartships - 165mm (6 1/2") The good news is that the oven performance is suprisingly good!
Post by MalcolmP on Apr 24, 2011 17:16:05 GMT
We find the square boaties fry-pan (with lid) www.boatiesfrypan.com/perfect on ours - we even have bought one for home Malcolm
