Post by tbetts007 on Nov 14, 2010 18:56:32 GMT
I have a 1994 SO 37.1. The propeller is currently at the bottom of the San Francisco Bay. I've located a new prop but can't seem to find the appropriate hardware (nut and washer) to attach it. I'm told by a reputable source that these are proprietary and not any metric nut/washer will work. Anyone have any experience with this? Any help is appreciated.
Post by MartyB on Nov 14, 2010 19:13:23 GMT
Have you tried the local dealer? Depending upon the proprietary source, the dealer should be able to get one. BUT, after 15 yrs, usually things are not the proprietary any more, and the correct metric nut should be available, Unless they used a funky thread count, or a 22.5MM instead of a 22 or 23 even size that might screw some things up.
