Post by ianqv on Nov 8, 2010 22:59:09 GMT
Fingers crossed someone may know......
How many litres of anti fouling will I need for my Sun Odyssey 37.
she's 2001 and has a shoal keel.
As always - many thanks in advance
Ian
Deleted
Deleted Member
Post by Deleted on Nov 9, 2010 15:47:25 GMT
For what it's worth, my SO35 with a full keel takes about 11 liters of anti-fouling which includes 2 coats.
Post by flightdeck on Nov 9, 2010 22:33:17 GMT
and my 2C, on our 32SO I used 8 liter's Micron Extra applied 4 coat's using a 4mm nap roller.
Post by Don Reaves on Nov 11, 2010 10:35:51 GMT
It depends a lot on the type of paint you use. Estimate the area to be covered or get it from Jeanneau (or maybe someone on this forum knows the area for your boat). Then read the directions for your paint; they should include coverage. Many paint manufacturers are willing to talk to you about application, and may be able to help you estimate better.
I've used about 5 quarts of VC17M (a fresh water paint) per coat on my SO35.
Post by sailbleu on Nov 11, 2010 14:42:56 GMT
One good coat for my 40 feet takes about 5 liters.
Post by davideso37 on Nov 16, 2010 12:23:30 GMT
Ian,
My SO37 with the standard keel takes 12 litres for a two coat spray job applied by professionals.
You tend to put on less paint with brushing than with roller coating and with roller coating the nap of the roller will dictate how heavy the antifouling is applied.
Whatever way you are going to do it, one coat of two, measure out the area roughly and spread the antifouling so that you get an even thickness using all the paint you have allowed.
Regards David
Post by ianqv on Nov 16, 2010 18:11:38 GMT
thanks for all the replies Guys. It'll be another couple of months yet before I antifoul. I'll let you know how its goes!!!
Post by gre2 on Dec 5, 2010 21:58:37 GMT
It likely depends where you sail and how thick or heavy you apply the anti-fouling but using VC17 I consumed just 2 litres of paint using a roller and only re-apply every two years. But we are sailing on Georgian Bay in the Lake Huron area so the water is reasonably cold obviously compared to the Caribbean. Hope this is helpful and not confusing. Liberte' SO 37
Post by davideso37 on Dec 6, 2010 8:15:46 GMT
gre2, Your anti fouling frugality will be the envy of the fleet. The manufacturer recommends 2 to 3 coats. www.yachtpaint.com/MPYACMDatasheets/VC_17m_Extra_with_Biolux+eng-usa+A4+Y+20100608.pdfThe other thing with VC 17 m is that the surface is sanded back to 320 grit so generally the surface to be painted is in excellent condition which helps to keep the usage down. I have tried a season with just one coat, in my case 6 litres but no matter what we do nine months later in the warm 19 degrees C of Sydney Harbour the growth is back. Two litres every second year would be anti fouling heaven here. Regards David
