whitebird
2003 Sun Odyessy 35
Post by whitebird on Oct 16, 2010 13:16:26 GMT
Does anyone know what the phrase "Prisma injection process" means in regard to the deck construction on our SO 35 (2003). Is there a core such as balsa or plywood, or is it a solid "plastic" structure that I can drill into with impunity, not worrying about letting moisture into the core and causing rot. I am an ex-C&C owner and that was a major problem with that manufacturer.
Post by renegade27 on Oct 16, 2010 14:05:41 GMT
Take a look at what the section of my 2006 SO35 looks like. I think the injection process creates the ribs that separate core areas. Wetting of one area won't propagate. I'd still fill holes with epoxy! img32.imageshack.us/img32/9660/july2509006.jpg
Post by rhb on Oct 16, 2010 22:14:54 GMT
The stuff between the inner and outer layers is foam??? Hard to tell for sure from the picture, doesn't look like balsa.
Post by renegade27 on Oct 17, 2010 11:08:34 GMT
Yes - Foam. Definitely not balsa. Fairly small cell size and brittle - you can sand it with your finger.
