Post by tpcook on Sept 19, 2010 18:48:25 GMT
Hello: I own a sun odyssey 52.2, which used the aquasignal overhead lamps. Recently I designed a replacement pure white 6000k 100 lumen circular led assembly of 9 SMD leds, which is much brighter and uses much less power than the standard 5w lamps used in the aquasignal units. These units are much cheaper than anything else on the market. Constant current design means that the light output does not vary from 9-24 volts. I also have G4 lamps which are used in the long overhead fixtures as well as rigid wire 44mm led assemblies. If your interested E-mail me at tpcook"at"videoautomation.com Webcrew edit: replace the "at" in above email with @see: jeanneau.proboards.com/index.cgi?board=terms&action=display&thread=1322
Post by Zanshin on Sept 19, 2010 19:12:33 GMT
Is this the same tpcook that I know from the BVI's?
I am looking into putting together some dimmable LED systems for my boat - using my own buck convert constant-current drivers and PWM dimmers and avoiding thecommonly used resistors that just drain power and create heat.
Post by yachtsea on Sept 20, 2010 21:41:34 GMT
Post by yachtsea on Sept 20, 2010 21:45:57 GMT
Forgot to say the LED'S are dimmable also, sailors solution also is comming out i am told with a new dimming lighting system, talked to them at the Annapolis show last yr. Hope its ready soon.
Gary ~~~_/) ~~~
Post by tpcook on Nov 6, 2010 17:52:51 GMT
Yup, same tpcook from the BVI. Just got back a couple of days ago putting Reef Song back in the water.
Post by Zanshin on Nov 8, 2010 10:37:40 GMT
In 2 weeks "Zanshin" is getting splashed again - see you at Leverick
