Post by mallorcaman on Feb 12, 2010 15:12:32 GMT
Hello all,
My first post on here. I maintain a 42DS and am struggling with the cutlass bearing removal. The similar post re: the SO35 helped a litttle, but not a lot! Does anybody have experience of doing this on this particular model? The bearing appears to be rubber/nylon, so I wouldn`t expect it to be epoxied in but it doesn`t want to budge in either direction. (I get the impression it can thoretically come out either way) Having said that, when I look through the grubscrew holes I can see what looks like stainless steel between the bronze of the p- bracket and the shaft. Some sort of sleeve, not visible at the ends? Can`t say I have ever seen such a thing. Removal of the shaft appears to involve removal of the rudder and associated lifting costs, which are substantial so I would be grateful for any advice before going down this costly route.
It would be very helful to know:
1. Is there any point heating it? 2. Can it come out forwards as well as backwards? 3. Or do I just have to do it the hard way - remove rudder and shaft then hack it out?
I prey for the voice of experience to answer me!
Post by gene on Feb 12, 2010 16:16:45 GMT
If it is like my SO40 then you have a strut with a cutlass bearing in it. The bearing is bronze sleeve with a rubber grooved bearing inside. Set screws lock it in place. A proper boat yard will have a puller that will do the job without removing the shaft. I have a poor picture of one on my old web site. Removing the shaft is not a bad idea however as you can clean up the shaft surface which will make the new bearing last longer. I just pulled the shaft loose on my boat to put in a PSS shaft seal and cleaned the bearing surface on the shaft at the same time. A yard had just put in a new cutlass bearing a few months ago using the puller mentioned above, but they couldn't clean the shaft surface properly. I would think you could remove the shaft without removing the rudder. The shaft on my boat was tapered and held in place with a nut on the end inside the coupling. Removing it using a puller is preferred over using a slide hammer. My boats page with picutures of shaft seal. santosha.info/index.htmlPicture of puller on my old boats site. sailors.hollosite.com/Boats/Now___Zen/Projects/Cutlass_Bearing_Puller/cutlass_bearing_puller.html
Post by mallorcaman on Feb 12, 2010 18:19:12 GMT
UPDATE: It`s out! Got it really hot with a heatgun and then used a piece of metal tube to knock it forward out of the p-bracket. Then cut it off the shaft with a hacksaw. Just hope I can get a replacement easily!
