Post by gerald1 on Mar 27, 2024 12:45:05 GMT
Our 2002 SO 32.2 lifting keel is so stiff it no longer drops under it's own weight. The plate and slot have been cleaned and the problem appears to be a seized pivot bolt which resists attempts at removal. Does anyone have any suggestions?
Post by MalcolmP on Mar 27, 2024 16:33:01 GMT
Hi Gerald Sounds likely as you suggest. This article should help. www.jeanneau-owners.com/hintsandtips/SO32liftkeel.htmlThere is a link at the end to the SO35 . Jeanneau tend to have very similar mechanism on every model. Please give the forum an update on how you get on. Good luck Malcolm
Post by gerald1 on Mar 28, 2024 9:54:40 GMT
