Post by mcgiver on Feb 22, 2024 21:55:41 GMT
Ceiling Panel Removal on 2015 Beneteau Gran Turismo GT49 I couldn't find the thread about a Prestige ceiling panel removal, but my experience with my lower salon ceiling panel removal is to start at one edge, most likely to need removal such as below the helm in my case. Gently pull the edge and separate the Velcro type bond then slide the panel out towards the Velcro edge. The next panel screws should be evident. Remove the screws and slide that panel out ... I have photos if I can upload.
Post by MalcolmP on Feb 22, 2024 22:52:52 GMT
Ceiling Panel Removal on 2015 Beneteau Gran Turismo GT49 I couldn't find the thread about a Prestige ceiling panel removal, but my experience with my lower salon ceiling panel removal is to start at one edge, most likely to need removal such as below the helm in my case. Gently pull the edge and separate the Velcro type bond then slide the panel out towards the Velcro edge. The next panel screws should be evident. Remove the screws and slide that panel out ... I have photos if I can upload. Probably simplest way to upload any photos is as attachments. Space is limited to 3 per post and maximum size of 1MB. If your photos are larger, they need to be reduced in size. There are lots of free apps that do that. You can of course do multiple posts if you have more than 3 images. You can direct message me if you want to know more. Malcolm
