mikej
Post by mikej on Feb 16, 2024 0:30:29 GMT
I have a 2022 NC795 (Series 1)- its was configured minimally by the previous owners so I am adding some equipment - like a VHF Radio.
On the fusebox below the sink there is a 15A circuit clearly labelled "VHF Radio" which is connected to an Orange/Black wire that disappears into the main loom and appears to head inside the loom towards the helm. However, I checked both the wiring behind the helm and below the throttle assembly and could not find that line terminated with a plug.
I can run another wire but it would be nice to use existing cabling.
I also do not have the manual for the boat (yet), it was a recent purchase and I need to look, it appears on a first pass Google search it is not posted anywhere. So no proper wiring diagrams.
Any help would be appreciated. ;-)
Mike
Post by ted415 on Feb 20, 2024 18:57:59 GMT
My VHF is mounted above the windscreen/helm to the left a bit. I can check if I have any diagrams next time im down there.
mikej
Post by mikej on Mar 3, 2024 3:27:41 GMT
My VHF is mounted above the windscreen/helm to the left a bit. I can check if I have any diagrams next time im down there. Thanks! - I ended up moving the stereo to the port side in front of the passenger seating and mounting the radio just above the helm wherethe radio was.Seems to be a good spot, overhead would be good too. I ran new wiring for power, it was much easier , but used the factory fuse position. Cheers Mike
