Post by bratwurzt1 on Feb 11, 2024 17:44:26 GMT
Hi All,
Changed the bellows in our dripless and thought about installing a flexible coupler before putting things back together. Looking for some feedback on brands and performance and if the money is worth it? Also does adding the small amount of length create an issue when under power? Here's a tip for removing the coupler from the shaft if you ever embark on that nightmare. Let it soak overnight with some kind of anti-seize and get a gear puller. Thanks in advance. 03' S/O 35
Post by Charlie-Bravo on Feb 11, 2024 21:10:04 GMT
An interesting idea, but not sure of the benefits for the price, ASAP £395 for a 25mm shaft. feel the shock loads when engaging gear should be mostly absorbed by the prop being surrounded by water, and unsure of the pro’s once the prop is spinning except perhaps compensating for errors in shaft alignment.
Interested to hear experiences of those who have fitted one, and the theories/ benefits, there seem to be quite a few on the market so someone thinks they are required, my shaft seems to spin quite smoothly (at the moment) without one.
Post by bratwurzt1 on Feb 11, 2024 21:55:34 GMT
Agree and thanks for the reply, eagerly waiting also.
Post by loredo on Feb 12, 2024 8:08:04 GMT
I wanted to install a Sigma Drive this years. I've heard a couple friends who installed that toy on their shafts. They reported smoother running, less vibration, less noise when motoring. Too bad, because of the shaft brake in my boat Bruntons would need to custom build it for me which takes a bit longer than what I'll be on the hard. I think there was a member on here which did a rather detailed post about the Sigma Drive installation and his findings???
Post by bratwurzt1 on Feb 12, 2024 10:15:03 GMT
I wanted to install a Sigma Drive this years. I've heard a couple friends who installed that toy on their shafts. They reported smoother running, less vibration, less noise when motoring. Too bad, because of the shaft brake in my boat Bruntons would need to custom build it for me which takes a bit longer than what I'll be on the hard. I think there was a member on here which did a rather detailed post about the Sigma Drive installation and his findings??? Ok thank you I'll look for it.
Post by loredo on Feb 12, 2024 10:51:06 GMT
I just did a search myself, there are a lot of infomations about the Sigmadrive on this site.
Post by ianf on Feb 12, 2024 11:45:48 GMT
I fitted a Sigma Dive on my boat four years ago and I'm very pleased with it. I also have a PSS dripless shaft seal and I believe that the smooth running reduces the wear on the graphite seal.
Post by MalcolmP on Feb 12, 2024 17:15:06 GMT
Another vote for tge Bruntons Sigmadrive. We fitted on 5 years ago, plus upgraded the OEM Prop shaft with a Duplex stainless shaft. The OEM had worn badly at the Volvo seal, noticeable grooves. The duplex is much harder, we still use the Volvo seal and touch wood totally drip free. Malcolm
Post by bratwurzt1 on Feb 13, 2024 10:20:33 GMT
Thanks for the feedback!
Post by MalcolmP on Feb 13, 2024 16:38:59 GMT
Hi Bratwurtz. If you decide on a Sigmadrive, contact Paul Bell on either 0044 7848 450779 or email: paul@firstmarinesolent.co.uk Mention Jeanneau Owners and Paul will give you a substantial discount and he really knows the product so can advise on the correct size and can also supply Duplex stainless Prop shafts and all sundries. Malcolm
Post by bratwurzt1 on Feb 13, 2024 17:02:45 GMT
Hi Bratwurtz. If you decide on a Sigmadrive, contact Paul Bell on either 0044 7848 450779 or email: paul@firstmarinesolent.co.uk Mention Jeanneau Owners and Paul will give you a substantial discount and he really knows the product so can advise on the correct size and can also supply Duplex stainless Prop shafts and all sundries. Malcolm Cool man! Thank you
