Post by xavierp on Jan 21, 2024 18:22:21 GMT
Hi all I need to temporarily remove the propane tank housing located in aft starboard locker I removed the screws around the housing and the housing is free BUT I don’t know what to do with the 2 gas lines that go from the tanks through the housing and to the inside of the boat. If i had access behind the housing that would be fine but I don’t. I can’t just push the lines out because I won’t be able to put them back…
Options ?
Thx!!
Post by Charlie-Bravo on Jan 21, 2024 20:45:18 GMT
Perhaps it would be possible to attach mousing lines to the gas hoses to be able to pull them back through the housing holes on re assembly , …… just a thought.
Post by zaphod on Jan 21, 2024 21:11:02 GMT
Perhaps it would be possible to attach mousing lines to the gas hoses to be able to pull them back through the housing holes on re assembly , …… just a thought. CB That's what I would do, although I am surprised there is no access from inside the boat.
Post by sunrise4 on Jan 21, 2024 22:21:06 GMT
On ours there is an access hatch in the stbd berth. Crawl in there and you should be able to reach around the propane tank liner.
VanVeiden
Yacht Name: Brizo
Home Port: Finike
Country: Turkey
Post by VanVeiden on Jan 27, 2024 10:05:37 GMT
Assuming you do not have a stock AC installed, as the stern unit is located right in front of the gas locker inside mould, if you try to access it from the starboard cabin grilled hatch.
Post by xavierp on Mar 16, 2024 11:12:07 GMT
Late thank you. i don’t know how to subscribe to get alerts!
Post by xavierp on Mar 16, 2024 11:12:25 GMT
Assuming you do not have a stock AC installed, as the stern unit is located right in front of the gas locker inside mould, if you try to access it from the starboard cabin grilled hatch.” Late thank you. i don’t know how to subscribe to get alerts!
Post by xavierp on Mar 16, 2024 11:12:53 GMT
Perhaps it would be possible to attach mousing lines to the gas hoses to be able to pull them back through the housing holes on re assembly , …… just a thought. CB That's what I would do, although I am surprised there is no access from inside the boat. Late thank you. i don’t know how to subscribe to get alerts!
Post by Don Reaves on Mar 16, 2024 12:35:57 GMT
To set alerts, click on the Profile at the top of the page. Then click the Edit Profile button. If you are using a computer, click on the Notifications tab. If you are using a smart phone, click on the word under "Edit Profile & Settings". For me, it's the first word in the list: Avatar. This will bring up a list of choices. Select Notifications.
From there the process should be self-explanatory. In particular, enabling Quote will notify you by email when someone quotes one of your posts.
Hope this helps. Don
