Post by MalcolmP on Dec 4, 2009 19:25:19 GMT
Just had the winter service done on my 40hp 3JH4-E engine
The service engineer reminded me that you can get false readings on the dip stick as there can be air pressure build up as the dip stick hole is also used to pump out old oil
I had noticed in the season that on checking the oil level that none showed on the dip=stick, loosening the filler cap allowed the system to rebalance and show a correct reading
Think this may be common to other newer Yanmar models
Malcolm
Post by grantgoulding on Dec 8, 2009 12:41:56 GMT
With my engine you are supposed to check ten minutes after shut down from running. I am guessing that's the same for all the newer Yanmars?
Post by MalcolmP on Dec 8, 2009 19:34:03 GMT
Grant Guess unlike me you read the manuals Malcolm PS maybe you could write up a few words with pics on your Biscay crossing?
Post by grantgoulding on Dec 15, 2009 16:45:57 GMT
I will put some words down and some pic's - yes would love to! Have a good Christmas incase I don't get to say that before then! Grant
Post by rca on Dec 16, 2009 4:15:51 GMT
Malcolm, many thanks for the update on the oil dipstick. I as well have the Yanmar 3JH and the in the my first year I was agast with no oil reading. Now into third year I play with the dipstick for a couple of days and have thought perhaps the dipstick with no oil adherance was a chemical issue with oil and dipstick metal. Now we know better and I will play with equalizing the sump pressure to confirm a hopefully accurate reading. Cheers and happy holidays to all.
Post by cplatt on Feb 2, 2010 1:13:44 GMT
Hello Malcom. The issues with the oil readings are related more to the pressure build up in the dipstick tube. While the engine is running air gets into the dipstick tube. Because the dipstick tube is at the bottom of the oil pan this air cannot escape, (the top of the dipstick is well sealed). All you need to do is remove the dipstick and reinsert it and you will find the correct level readings.
Good Sailing Corbett
Post by gene on Jun 29, 2010 14:37:19 GMT
On my 4JH3e it seems like the only way I can get an accurate reading is to remove the dip stick and the oil fill cap and wait a few minutes for it to equalize. I generally check the oil when it's cold after it has been sitting for a week or more. I do not have an operators manual so I am glad Malcolm pointed this out. Thanks!
Gene
