Valor323
Jeanneau Model: 41 DS
Yacht Name: Ciao Bella
Home Port: Glen Cove
Post by Valor323 on Jan 8, 2024 3:08:04 GMT
Hi Since it was so cold in NY, I decided to fie up the heat gun today and stripped the old, god awfull dark brown finish off of the stairs. The non slip tape adhesive left the wood discolored. Any tips or tricks to get the tape stains off of the wood? Thanks in advance!
Post by Don Reaves on Jan 8, 2024 10:54:20 GMT
I would plan on replacing the non-slip tape, since it's very useful. With the correct placement, you probably won't notice the original discoloration.
Post by Charlie-Bravo on Jan 8, 2024 18:23:35 GMT
A good dual action sander (with vacuum attachment) will remove the stains, 80 grit disc to start, and then 120 and 240 grit, , but as suggested, non slip is going to be required, one fall slipping off a companionways step can spoil your sailing for ages, so I second Dons advice.
The steps look good, must attack mine one day.
Valor323
Post by Valor323 on Jan 9, 2024 3:34:03 GMT
A good dual action sander (with vacuum attachment) will remove the stains, 80 grit disc to start, and then 120 and 240 grit, , but as suggested, non slip is going to be required, one fall slipping off a companionways step can spoil your sailing for ages, so I second Dons advice. The steps look good, must attack mine one day. CB It wasn't a horible project. I stripped the varnish off of the cockpit table, the companionway teak trim and the steps in about 4 hrs. I set the gun to about 740 degrees and the finish came off quick with just a putty knife. No sanding at all. The dark brown step color seems to make the steps so much more noticeable. Its a lot easier on the eyes in a lighter color. IMHO. Agreed, nonslip is a requirement, however I am exploring my options. Considering a Seadek teak and holly or similar EVA foam material or a varnish with non slip additive, but we will see. Not sure which direction I will take but I have some time to decide, since it's still so cold. I really can't do much with this until the temp gets above 50f. For those of you that have done this, which direction did you ultimately go? What are you guys doing with your cockpit tables? Semco teak sealer? Cetol? Varnish? Cheers!
Post by MartyB on Jan 9, 2024 4:50:39 GMT
You might also look at Kiwigrip or Petits Tuff Coat. Both are a rubber style non skid. Apply this over the flat part of the steps, you can then make the non skid area bigger than what you have. In my case, it is 2-3 times larger in area with Kiwi Grip, and much nicer going up and down the stairs.
Post by sailor666 on Jan 9, 2024 20:28:46 GMT
