idahoannie
Jeanneau Model: 795 S2
Yacht Name: Yacht Sea
Home Port: Coeur D’Alene ID
Post by idahoannie on Dec 31, 2023 2:54:30 GMT
Does anyone know what the “wood look” material on my NC 795 S2 is? (On the walls, cabinets, door to the head and table)
thank you
Post by laser85jb on Jan 2, 2024 0:25:37 GMT
On our 2023 NC795 S2, it is very thin plastic veneer, with a wood grain pattern, over a plywood core. All visible edges of the plywood are banded with the veneer as well.
Post by laser85jb on Jan 2, 2024 18:24:41 GMT
If you look at the little triangular forward berth fill in piece, you will see the typical plastic Formica/plywood configuration. The exposed plywood edge has Formica where it can be seen, but the plywood is simply stained on the edges not typically visible. I noticed that the cabin table is constructed the same.
