Jeanneau Leader 8 few questions
Nov 27, 2023 20:29:51 GMT
Post by rebekic on Nov 27, 2023 20:29:51 GMT
I have a few questions regarding my Leader 8 (2014) – Jeanneau FR-SPBTS258G314
1. Regarding the toilet. I have a mechanical toilet (photo attached). I would like to replace it with an electronic toilet (maybe with Mercator). What exactly I should be looking for when buying, keeping in mind the space behind the toilet and measurements of the drainage pipes, and finally the waste system altogether?
2. How does this mechanical toilet work exactly? I acquired a boat a few weeks ago and still have not figured it out, when I pump waste from the toilet it goes "somewhere” but after a while, it comes back into the toilet and almost overspills from the toilet bowl. The valve for discharge into the sea is open but still, it does not go into the sea. (attached)
3. Is it possible to obtain a Service manual (spare parts) since I am located in Montenegro and the only option to order parts is via serial numbers since you don’t have a dealership in Montenegro so it would be much easier for me to get the parts this way?
4. Most importantly, regarding battery breakers, can you please elaborate on all switches? Since on the first switch (Board and Domestic – Photo attached) when I press the switch the “domestic” turns to red, but “board” is always green (stays in green whatever I do). While the rest of the switches are changing from green (on) to red (off) when pressed. Please explain to me in detail the function of the breakers so I know which breaker is for which battery and explain to me if you can why is “Board” always in green.
5. I want to install water sensor level for my 100l water tank on Jeanneau Leader 8. I have a photo of water tank but can not find specification (dimensions) for water tank. My boat is out of the country. Does anyone knows dimensions of water tank and which is the best sensor with gauge (or compatible with my E-series MFD Raymarine) that can fit
Thanks in advance
