41DS Raymarine Help
Oct 19, 2023 14:04:35 GMT
Post by Valor323 on Oct 19, 2023 14:04:35 GMT
Hi everyone,
Just completed a 12-day sail from Gulf coast Florida to Long Island Sound, New York a few days ago. The entire Raymarine network started to fail along the way including the autopilot. We eventually shut the whole thing down and just used Navionics to chart and hand steered for about 6 days.
I am now trying to do some trouble shooting of the Raymarine system and I am not sure where all of the connections and backbones are located to possibly see what is creating the issue.
What I have found so far:
Obviously, the Raymarine chart plotter, ES series, in the cockpit pod.
Autopilot computer and compass in the aft cabin, port side.
2 Tee connectors aft cabin, port side under the side seat backrest. Seems to control the 2 I70's and the 1 autopilot display on the helms. 1 spur cable goes to the compass.
1 Backbone and an ITC-5 converter at the nav station behind the switch panel. The anemometer is the only thing connected to the spade connectors of the ICT5.
The rudder sensor and the Autopilot head and ram are in their obvious locations. Not sure where the rudder sensor terminates yet.
The depth sensor is present, not sure where it terminates to.
I'm guessing there needs to be more to this system than that. Any insight would be very much appreciated.
Just to float this out to the group, all of the lights on the ITC5 are blinking quickly. The manual states this indicates a low voltage bus issue. I think my initial course of action will be to locate the 12v tap and check the supply voltage before moving on. If there are any electronics experts that can offer a hand, it would be greatly appreciated. Thanks in advance.
Michael
Michael
