SO40DS furling main jam
Oct 2, 2023 2:47:43 GMT
Post by cpetku on Oct 2, 2023 2:47:43 GMT
So like SailBlue (when he had a 40DS), I've had problems with my mainsail jamming on deployment. The sail goes to a loft for service every year and they can't find anything stretched to explain the issue. Usually it's the leach side folds over and won't easily pull out of the mast.
Today was a really bad jam taking the better part of five hours to clear up eventually getting the foot unfurled to the tack to allow dropping the sail.
Yes it was a bad day, but I had a hint of this last week and tried deploying the main at the dock under light wind when it jammed. Nowhere near as bad as a jam while deploying on water (as ocurred last week but I was able to get it out over the course of 30 minutes while entertaining crew).
The highlight today was when the stitching on the clew webbing gave way while trying to pull out the sail using the manual winch. I know there was a lot of tension, but I didn't go overboard on the winch. I ended up using vice grips to capture the thick material of the clew (where the straps were sewn to) and spent a couple of hours jerking away at the sail to get as much out as I could. In the past I found that shock loads allow getting a jammed sail to free up.
Dropping the sail, it doesn't make a lot of sense how the last five feet at the head/top could have so much material inside left the mast and fouled. Pulling the last four or five feet of sail out the track while removing the main from the mast was really difficult.
While the sail looks reasonable on the ground and has been serviced every year (for the past 10), I'm wondering if the head is what's stretched (not the belly) causing my issue. Since the sail is probably pushing 18 years, I've decided to splurge on a new one for next year since I replaced the Genoa this spring.
Should I ask that the straps on the new sail's clew block be covered with UV blocking material to avoid damage to the thread? I didn't think we had that much issue with UV where I sail. Then again, I'm seeing thread failures on a dodger which I had remade by a small shop a few years ago.
