Post by knotsmart on Sept 17, 2023 20:24:26 GMT
Good afternoon everyone
In my engine compartment I am trying to identify 3 red wires. The wires are probably 14 gauge and have 7.5 blade fuses. The. Wires have the clip on type labels. They are..
VA VE VM
I went through the French owners manual and I think I identified VE as "bilge fan power" which I assume is the ventilation fan for the engine compartment (I didn't put power to it yet to verify) ..
Any guidance is greatly appreciated
Thank you
Post by tsenator on Sept 18, 2023 16:00:24 GMT
Good afternoon everyone In my engine compartment I am trying to identify 3 red wires. The wires are probably 14 gauge and have 7.5 blade fuses. The. Wires have the clip on type labels. They are.. VA VE VM I went through the French owners manual and I think I identified VE as "bilge fan power" which I assume is the ventilation fan for the engine compartment (I didn't put power to it yet to verify) .. Any guidance is greatly appreciated Thank you I’m not 100% sure but maybe it’s the wires for the panels voltmeter (VM voltmeter Motor) and (VA Voltmeter Auxiliary). I found it in the manual for electrical wiring . The page that shows the wiring harness and the connectors (labeled “Tableau Electrique 12v DC)
Post by knotsmart on Sept 19, 2023 10:54:06 GMT
ding ding ding.. you are correct sir.. i went back in to the french manual.. on the original panel (which i no longer have) there is a dc volt meter and a selector switch that toggles between "bat bord" , "bat moteur" and "bat aux".. vm is bat moteur and va is bat aux
thank you soooo much..
greatly appreciated.. you have a good one sir
