Post by philsundream28 on Jul 25, 2023 10:45:50 GMT
Good morning. I own a Sun Dream 28 (1988) and wish to understand what the deck construction is especially around the sheet track. I do not have a problem but wondered if anyone in the forum knows or could point me in the direction of someone who might. Thanks for your help.
Post by MalcolmP on Jul 25, 2023 12:40:34 GMT
You are very welcome to our forum.
Not 100% sure, but most likely your Sun Dream will be traditionally laid up fibreglass. They probably have put in plywood in high stress areas like the sheet tracks, winches and cleats. Probably has end grain balsa in the larger areas to stop flexing.
Enjoy your boat.
Malcolm
Post by philsundream28 on Jul 25, 2023 14:02:04 GMT
Thank you Macolm. Thanks for the prompt reply. We do enjoy the Sun Dream 28 but just have a question regarding the deck. Do you, or anyone else have any suggestions as to how we might find out (without drilling a hole that is )? Thanks Phil
Post by MalcolmP on Jul 25, 2023 15:18:28 GMT
Thank you Macolm. Thanks for the prompt reply. We do enjoy the Sun Dream 28 but just have a question regarding the deck. Do you, or anyone else have any suggestions as to how we might find out (without drilling a hole that is )? Thanks Phil Hi Phil There should be several holes already such as for cable glands around the mast. They are always worth re-beading with new mastic, so if was me I would remove a couple, clean the hole and that should let you know the construction. cheers Malcolm
Post by Charlie-Bravo on Jul 25, 2023 18:24:25 GMT
And/or, pull a sheet track bolt out and have an investigation of the exposed hole, re seal , pop the bolt back in , and you have your answer. Probably a solid lay up 8 to 10mm thick.
Post by philsundream28 on Jul 26, 2023 8:05:36 GMT
Thank you Macolm. Thanks for the prompt reply. We do enjoy the Sun Dream 28 but just have a question regarding the deck. Do you, or anyone else have any suggestions as to how we might find out (without drilling a hole that is )? Thanks Phil Hi Phil There should be several holes already such as for cable glands around the mast. They are always worth re-beading with new mastic, so if was me I would remove a couple, clean the hole and that should let you know the construction. cheers Malcolm Thank you
Post by philsundream28 on Jul 26, 2023 8:05:57 GMT
And/or, pull a sheet track bolt out and have an investigation of the exposed hole, re seal , pop the bolt back in , and you have your answer. Probably a solid lay up 8 to 10mm thick. CB Thank you C-B
Post by MartyB on Jul 28, 2023 2:56:26 GMT
My 85 Arcadia, version before the sundream is about 25-30% glass at top and bottom, remaining 40-50% in the middle appears to be balsa. I've replaced the genoa tracks along the cabin once. I've also added some SS supports on the top of the deck as it has tried to separate from some supports below deck. These supports appear to be a solid wood of some sort.
