Post by shellbeach on Jul 22, 2023 15:49:47 GMT
Recently bought a 2017 and trying to sort out how to empty the holding tank while at sea. There’s a valve under the sink in the head with a nearby label that says ‘Flushing outlet vidange WC’ and I assume we should open that while the engines are running, then press the macerator control button that’s on the wall next to the toilet. Sound about right?
Post by Hanzel on Jul 23, 2023 8:37:36 GMT
Post by shellbeach on Jul 23, 2023 13:29:02 GMT
Thank you Hanzel! I had read the earlier thread about the macerator pump not working, but was hoping someone could confirm the exact process. Appreciate you taking the time to bring it to my attention again. Unfortunately the owners manual just tells you to ‘open the drain’ but doesn’t specify the location of the drain, or how the effluent is moved out of the tank. In this case the tank is below the level of the valve I found, so if it’s the correct valve, there must be a pump and I expect that’s the macerator - just wanted to confirm.
