TomFrd
Jeanneau Model: SO 45.2
Home Port: Hamburg
Country: Germany
Post by TomFrd on Jul 11, 2023 9:10:41 GMT
Hello, Hello, I own a SO 45.2 from 2001 and in the Cockpit there seems to be some modification made which were not expected when manufactured. Now I am looking for a original description or picture to check what happened. Could anybody with same "ventilation system" provide a picture from inner hull side? Thanks for help Tom P.S.: Please check the pictures from our boat.
Post by Zanshin on Jul 11, 2023 10:12:55 GMT
So many of the boat classification rules specify how long it may take for a cockpit fully filled with water to drain. This modification means that if the cockpit should fill with a big wave the boat may sink rather than drain...
I can only think of additional ventilation for the engine. Is there a corresponding vent/opening around the engine compartment?
Post by Don Reaves on Jul 11, 2023 12:28:12 GMT
Was there a speaker for the sound system located there?
TomFrd
Home Port: Hamburg
Country: Germany
Post by TomFrd on Jul 11, 2023 13:04:51 GMT
No speaker etc. mounted.
Yes, the ventilation maybe there for the motor - there are some tubes ending down below but sure they were never connected to those holes.
I guess a kind of "camin" upside to allow getting air possible from machine
Post by Zanshin on Jul 11, 2023 16:11:20 GMT
Kamin = Chimney for the others. Perhaps it was thought to be simple ventilation, but that picture on the inside looks like there was a PVC tube in there too. I'd just put a speaker in there to plug the hole
TomFrd
Home Port: Hamburg
Country: Germany
Post by TomFrd on Jul 11, 2023 20:40:52 GMT
Ok, it seems to me that someone had cut the connection to the motor ventilation.
Not sure how it was mounted originally but the connection element seems to be destroyed on my boat :-(
web
Post by web on Jul 12, 2023 12:06:32 GMT
I have a '98 45.2 and those have ducts from the engine room ventilation fan. Only comes on when things get too hot down there.
Post by Zanshin on Jul 12, 2023 16:30:31 GMT
web - is the assembly in the cockpit identical to that in the picture?
TomFrd
Home Port: Hamburg
Country: Germany
Post by TomFrd on Jul 13, 2023 6:59:57 GMT
I got feedback from Jeanneau. The original part is shown on foto 1 and that is installed under the white cap. To that the ventilation tube is connected normally. Mine looks like foto 2 from inner the cap. I ordered 2 new connectors Thanks for help here
