papawads
Jeanneau Model: SO 43 DS
Country: Greece
Post by papawads on Jul 2, 2023 18:07:13 GMT
This may be hard to explain, please be patient!..
I appear to have 'movement' in the structure of the fridge.
The large RH side lid, seems to have moved right, almost catching on the worktop when closing.
The white plastic 'T' bar, at the top of the wall, separating main compartment from smaller (central) one, is 'coming apart' at the front edge.
Has anyone else had this?
Not sure how to get at the internal structure to screw things back in place.
Any views welcome. :-)
Papawads
Post by saltymetals on Aug 9, 2023 8:34:55 GMT
I have noticed the same thing on my boat but only a few millimetres of movement. I think it is the narrow vertical strip to which the hinges of the fridge lids are secured. I have no idea how to fix it but probably means you need to partly dismantle and extract the cupboard unit above the hinges in order to get to the back on that narrow strip. I would be interested to know what solution you find since looks as though i will soon have to be fixing the same prblm.
A couple of years ago i ditched those wretched springs which hold the lids open since you never know when the lids will come crashing down on your hand or arm. I replaced the springs with pressure struts and of course when the lids are closed these pressure struts are pushing the lids forwards and i think this is what is creating my problem of the lids appearing to have shifted slightly.
Andrew
"Genial Bee"
