toms
Jeanneau Model: NC 1095
Yacht Name: Dos Tamales
Home Port: Saltspring Island
Country: Canada
Post by toms on Jun 16, 2023 15:13:40 GMT
On my 1095, the holding tank is filling up without using the toilet. I have the through hull valve open, so my only guess is the through hull valve is leaking. I would have thought the macerator would have a back flow valve which would prevent water coming back from the through hill fitting. So I can’t figure out any other reasons the holding tank is filling up. There is no water in the hull, the toilet works fine, and the holding tank empties in about 3-4 minutes of pumping. Any help or suggestions would be appreciated.
Post by stephenm27 on Jun 16, 2023 23:55:42 GMT
On my 1095, the holding tank is filling up without using the toilet. I have the through hull valve open, so my only guess is the through hull valve is leaking. I would have thought the macerator would have a back flow valve which would prevent water coming back from the through hill fitting. So I can’t figure out any other reasons the holding tank is filling up. There is no water in the hull, the toilet works fine, and the holding tank empties in about 3-4 minutes of pumping. Any help or suggestions would be appreciated. The overboard discharge thru-hull should remain closed until you are actively discharging waste overboard (running the macerator pump). There is an inline back flow valve between the macerator and the thru-hull but it should not be relied upon to prevent the boat from taking on water. If the thru-hull is left open for an extended time, the tank will fill up to the waterline of the boat, which I believe is above the top of the tank…meaning you will have wastewater pushing thru the tank top and vent.
