markvb
SO37
Jeanneau Model: SO37
Yacht Name: Whisky Mac
Home Port: Dinteloord
Country: the Netherlands
Post by markvb on May 1, 2023 15:23:20 GMT
I am going wild on improving everything with Acrylic or Polycarbonate material. I am currently replacing the windows of our SO37 and also want to install a splash back plate made of Perspex (10mm). However Jeanneau parts are expensive so I want to make this myself. I made a design and want to machine cut it. So if anyone needs the same, or slightly different version, let me know! I can deliver you the DXF. These are the clamps I have in mind. I am still in doubt if these are nice. Any tips are welcome!
Post by Tafika II on May 1, 2023 22:18:22 GMT
May I suggest the material you decide to use for the backsplash have an anti-abrasive coating? Unprotected PMMA scratches. Also, I suggest you round the top of your brackets vs 90 degrees to prevent them from digging into the PMMA material.
markvb
SO37
Post by markvb on May 2, 2023 14:07:53 GMT
Good suggestion. I will look into it!
Post by bereboot on May 3, 2023 6:54:45 GMT
The supports for the jeanneau backsplash are higher (15 cm). Once installed you will see that someone will use it as a handhold in an emergency so more support is perhaps better?
Post by sitara on May 4, 2023 22:25:12 GMT
markvb
SO37
Post by markvb on May 12, 2023 13:07:33 GMT
Thanks you for the feedback. I decided to engineer the backsplash as sitara suggested. I changed the brackets to the ones sitara suggested and made an extrusion for the brackets so the panel will be flush.Also I made an opening for cleaning underneath
markvb
SO37
Post by markvb on May 14, 2023 19:03:51 GMT
Post by Don Reaves on May 14, 2023 20:37:16 GMT
Very nice job.
Aside from the color of the throw pillows, that could be my SO35.
