Post by joedunn on Feb 28, 2023 10:16:09 GMT
HI, I have a 2018 SO419 and would like to add a second propane tank. There is space in the lazarette to add the second tank but it needs to be the same size. It is smaller than a standard grill tank. I have attached photos of the markings on the tank. I am not sure if all 10.7L tanks are the same dimension? Does anybody know where I can purchase a tank so it fits? Thanks in advance-
Post by rene460 on Feb 28, 2023 10:39:44 GMT
Hi Joedunn,
I had a similar issue with the tank sizing when I eventually needed to replace the two propane tanks supplied with the boat originally. It turns out that the standards cover the volumetric capacity of the vessel, but not the actual height or diameter. You may find the standards in your area of the world much the same. In addition, the top protector collar for the valve seems to vary in size from one manufacturer to another. I found I had to take a tape measure with me and a note of the maximum overall height and diameter that would fit. If you look in the storage cage of a typical “swap and go” outlet, you will often see a selection of sizes.
The locker on the SO30i only had room for one bottle, so I carried the second in the life raft locker as a convenient well ventilated space. As with the home bar-b-que, the bottle runs out only when you are cooking, so a spare to enable a quick switchover is essential.
Post by joedunn on Feb 28, 2023 23:08:54 GMT
Thank you!
Post by bratwurzt1 on Mar 19, 2023 11:06:22 GMT
Just bought a new one for our 2003 S/O 35 that has room for two in the rear lazarette. Here is what I bought and it fits, Flame King YSN10LBa 11 Pound
Post by Tafika II on Mar 19, 2023 16:08:41 GMT
Here's what we purchased for 08 SO42DS...Worthington LPG Cylinder 299889
Post by joedunn on Mar 25, 2023 8:35:35 GMT
That's great Thank you both!
