Volvo MD2020 (and others) heat exchanger corrosion
Feb 20, 2023 16:09:29 GMT
Post by mikebz on Feb 20, 2023 16:09:29 GMT
Investigating a salt water leak from my MD2020D (about a teaspoon of water soon after startup, and no more after that) I found it was wet around the exhaust elbow (S/S fabricated item from Keypart) and the lower RHS stud nut was very rusty. Removed the elbow and found the weld between the tube and the flange had cracked. That was minor compared to this:
After removing the studs and brushing off the loose bits:
The yellow circle approximates to where the hole in the gasket would be.
The notch is where I've attacked it with a file to find some solid metal. I wonder if the corrosion has been exacerbated by having a S/S elbow.
I think this is may be salvageable by milling around 7-8mm off and making a 7-8mm spacer to go between the housing and the elbow. If the spacer were aluminium and had a slot to match that in the housing rather than a circular hole then that would give some protection to the face of the housing, and the spacer could be considered sacrificial in and replaced when it has corroded sufficiently.
However... despite that fact that the engine was running fine I find that turning it over by hand there is good compression on #1, some compression on #2 (hissing of escaping air), and nothing discernable on #3. I've been told that #3 is prone to this being so close to the exhaust, the valves can rust. So next job is head off to have a look at the valves and valve seats.
Having trawled the internet I find similar issues with the heat exchanger housing on other Volvo engines (D2 55, MD2030) especially on the Bavaria owners forum.
So next time you check your exhaust elbow also check the state of the heat exchanger face that it mates to.
