mnbuarque
Jeanneau Model: SO DS 50
Yacht Name: Carmel
Home Port: Paraty
Country: Brazil
Post by mnbuarque on Dec 16, 2022 14:43:47 GMT
Hi J-owners,
Has anyone a clue about where I can find the dimension of the original sails of my boat (SO DS 50) ?
BR Marcelo
Post by zaphod on Dec 16, 2022 17:36:42 GMT
Do you mean the dimensions of the actual sails that came with your boat? The only way to know that for sure is to measure them. The sails would have been contracted out to a sailmaker, and they would have made their own decisions on exact measurements.
If you mean general sail dimensions you can use rig measurements found on sites such as sailboatdata.com. Sailmakers all have access to rig dimension databases.
If you are planning to order new sails it is always a good idea to actually measure your own rig in case it is different from the numbers listed in databases.
Post by Tafika II on Dec 16, 2022 18:52:33 GMT
I contacted Gilles Rigaux at Jenneau USA (grigaux@jeanneauamerica.com) and gave him my hull number, year and boat (SO42DS) and they sent me the factory dimensional drawings in a PDF format. They are guidelines only and should be measured by you or your sailmaker to confirm.
Post by NZL50505 on Dec 16, 2022 21:12:06 GMT
See here the sizes as measured by my sailmaker when replacing my 50DS sails (note I have in-mast furling).
mnbuarque
Yacht Name: Carmel
Home Port: Paraty
Country: Brazil
Post by mnbuarque on Dec 19, 2022 17:56:30 GMT
Thank you very much !!! That's all I need !!
