Post by lupinglade on Oct 27, 2022 6:17:01 GMT
I noticed the sliding roof hatch is a bit difficult to operate - I tried cleaning the tracks but it didn’t do much. Does anyone know if this is normal or if it needs some lubrication or something similar? Thanks!
Post by bereboot on Oct 27, 2022 6:58:54 GMT
On our 39i îve applied some silicon spray. Most of the problem solved.
Post by lupinglade on Oct 28, 2022 3:19:27 GMT
On our 39i îve applied some silicon spray. Most of the problem solved. Thanks! I’ll give that a shot.
Post by Don Reaves on Oct 28, 2022 10:13:10 GMT
I found on my SO 35 that lubricating the tracks wasn't enough because there was friction along the forward edge where the hatch slides over the fiberglass. So I also sprayed the underside of the hatch, and it solved the problem.
