epsilon
Jeanneau Model: 2012 SO 36İ 3 Cabins
Yacht Name: EPSILON
Home Port: Kuşadasi
Country: Turkey
Post by epsilon on Oct 9, 2022 18:48:26 GMT
I can not finf the Hull number on a Sun Odyssey 519, normally I would think, it will on a plate under the engine or stamped in, on stbd aft quarter.
This is specific question for a Sun Odyssey 519, I really like the find out the stamped in Hull number location, cheers
Post by Don Reaves on Oct 9, 2022 19:00:34 GMT
If the 519 is like other Jeanneaus, it will be on the starboard quarter, not far below the gunwale. Typically, they are quite faint and hard to see except in the right light.
epsilon
Yacht Name: EPSILON
Home Port: Kuşadasi
Country: Turkey
Post by epsilon on Oct 9, 2022 19:27:04 GMT
If the 519 is like other Jeanneaus, it will be on the starboard quarter, not far below the gunwale. Typically, they are quite faint and hard to see except in the right light. Thank you for your reply mate, I had a 36i and 409 I found the hull numbers on those models quite easy on the starboard quarter, but can not locate it on SO 519
