Post by fmilner on Sept 15, 2022 10:25:19 GMT
I have a Yanmar 3YM20 on my SO 32i which had a new shaft, Volvo seal, cutlass bearing and alignment a couple of years ago.
The engine is smooth up to about 2200 revs then I get a vibration underfoot which dissapears at about 3000 revs and above. No vibration when I run in neutral.
Has anyone had a similar problem?
Frank
Post by tilo on Sept 15, 2022 18:41:31 GMT
A lot can happen in the "couple of years" since the last alignment. It's probably something simple, like a poorly attached anode, or something attached to the prop. If there's no play in the shaft and cutlass bearing, then I would look at engine mounts next. Maybe one of them is failing.
Post by fmilner on Sept 18, 2022 9:08:00 GMT
Thanks for your advice. I have noticed a small dent in one of the prop blades so will straighten this out and see if it makes a difference. Failing that it sounds like engine mount replacement.
Post by bereboot on Sept 18, 2022 12:50:41 GMT
Possibly a problem with the prop shaft?
