Post by bottleinamessage on Sept 2, 2009 15:42:13 GMT
Greetings all:
I have a problem with leaking propshaft seal. I had the packing replaced a couple years ago and it leaks....alot. I took it apart and found four wraps of flax. I suspect that the yard used 1/4" packing which I believe is too small. 5/16" appears to be too big. I believe that I need (and would love to find a source for) teflon packing material in metric sizes.
Hope someone will come to my rescue. Thanks, Jay
Post by bottleinamessage on Sept 19, 2009 11:31:48 GMT
Problem is solved. The yard did it fact use a packing material that was undersized. I repacked using a teflon impregnated 5/16" packing material. Three layers with the joints 180 degrees apart should solve the problem. We'll know when the boat is re-launched.
