Post by bandicoot on Jun 30, 2022 8:33:09 GMT
Hello all,
Im currently facing a problem regarding the deck lights. When I turn the deck lights on , I get light to the back of the boat , I get light to the top of the sail , but at the nose nothing. I checked the lamp it was allright ( even connected it to a 12v battery and was ok ). Last season everything was working great. My question is : does those lights have fuse independently from each other ? ( back/top/nose lights). If yes can someone tell me where is the fuse box located, I tried to find it but couldn't.
Thank you all in advance.
Post by Trevor on Jul 2, 2022 11:43:32 GMT
Hello bandicoot and welcome to the forum. Certainly in the SO 36i the fuses are behind the switch panel but I think your vessel maybe a little older than that.
Does that mean your nav lights don’t work unless you turn on your deck light switch?
Post by Trevor on Jul 2, 2022 11:47:14 GMT
Sorry just reread the post….. it would be very unusual if those lights are separately fused. I would look for the common point of distribution and work forward until you find the break.
Post by bandicoot on Jul 4, 2022 4:37:17 GMT
Hello bandicoot and welcome to the forum. Certainly in the SO 36i the fuses are behind the switch panel but I think your vessel maybe a little older than that. Does that mean your nav lights don’t work unless you turn on your deck light switch? Trevor Hello and thank you for your answer , when I say deck lights I meant navigation lights, sorry . The lights that others can spot you ( back,top, nose ) .
Post by Trevor on Jul 4, 2022 9:42:23 GMT
Hello bandicoot,
If the lights forward are not working I assume that is two lights, one green and one red both not working. Sometimes the light socket on the pullout gets corroded so that may be a good start to check. You could purchase a small inexpensive meter to check for voltage on the socket and work back through the boat until you find voltage on those wires. If the stern light is working I would guess the fuse is ok as in my experience the nav lights are fused together.
Let’s know how you get on. Regards, Trevor
