nigelhopkins
Jeanneau Model: Sun Odyssey 42i
Yacht Name: Skiron
Home Port: Preveza
Country: Greece
Post by nigelhopkins on May 15, 2022 19:27:18 GMT
So we've had 3 days on out 2010 Sun Odyssey 42i and still trying to get used to some of the unique noises the boat makes. In the night there's one really strange noise. It is similar to the sound an empty bottle would make if you pushed it underwater in a sink. The kind of 'burble/gurgle' of air in water. It would happen 3 or 4 times then stop and then start again randomly a few minutes later. Sometimes it would happen 3 or 4 times, then maybe once and then twice etc.
Could it be, Air escaping from the vents to the holding tanks?
It seemed to happen in the early hours when a) I was too tired to move and b) it's difficult to be sure where the noise is coming from.
Any ideas or experience of this would be appreciated.
Post by NZL50505 on May 15, 2022 21:30:44 GMT
Have you tried putting the plug into the wash basin. Mine gurgles when at anchor in anything other than flat calm water.
nigelhopkins
Yacht Name: Skiron
Home Port: Preveza
Country: Greece
Post by nigelhopkins on May 16, 2022 5:52:19 GMT
That's a possibility! Thanks you I will try that when I'm back out in June.
Post by tomina on May 17, 2022 14:58:54 GMT
I have a funny feeling that what you are describing is water slopping gently back and fore in the forward water tank……are you sleeping in the vee berth forward. In which case you are likely on top of the tank and a part filled tank will ‘slop’ about making these gurgling noises. So, either empty the tank and listen. Or, fill it and listen! That should confirm one way or the other. Mine gurgles best at about two thirds full!! Hope that helps Michael Solano & Julia Too
nigelhopkins
Yacht Name: Skiron
Home Port: Preveza
Country: Greece
Post by nigelhopkins on May 17, 2022 15:22:53 GMT
Hi Michael and Julia Thanks for the response. It's not actually that although we have definitely experienced what you describe! Jeanneau clearly went for low cost water tanks without baffles. I was going to start a separate thread to see if anyone has managed to add baffles or replace their tanks and solve this problem as what you describe is very frustrating.
Post by tomina on May 17, 2022 17:55:41 GMT
Well Nigel. If you have ruled out the water tanks, what about small waves slapping under the counter at the stern. This can be so bad on larger boats (upsetting the charterers aboard) that they manufacture special shaped inflatable tubes to mitigate this problem. More than that I can’t think of anything else. Michael Solano
nigelhopkins
Yacht Name: Skiron
Home Port: Preveza
Country: Greece
Post by nigelhopkins on May 18, 2022 7:39:31 GMT
Thanks Michael. I'm interested in the inflatable tubes. Do you have a link?
Post by NZL50505 on May 18, 2022 23:52:41 GMT
If you Google transom slap you’ll find tons of stuff.
I doubt that’s the gentle gurgling noise you heard - you ‘feel’ as well as hear transom slap as the waves thump under the stern. If a big boat wake comes through from the stern it can be quite an alarming sound!
Post by sawduster on Jun 7, 2022 19:19:14 GMT
We sometimes get this from water moving up and down through the kitchen sink seacock making gurgling noises up through the sink drain. We noticed it one windless evening with a slight side swell which was rocking the boat from side to side. Try closing that to see if it helps.
nigelhopkins
Yacht Name: Skiron
Home Port: Preveza
Country: Greece
Post by nigelhopkins on Jun 13, 2022 19:52:22 GMT
Thank you. This sounds like a potential cause. It's so difficult to be sure at night when a) you're tired and b) you've overdone the food and drink! I am back out on the boat from Sunday so will be trying all of these to see if I can figure it out and will feedback.
