Post by carterj22 on May 10, 2022 16:03:02 GMT
My starboard nav light it out. Checked bulbs etc and all ok. Port working fine, so power is getting through. I understand from the electrical schematic diagram there is a Nav Lights Terminal Strip, Im hoping there is a loose connection or something. Does anyone know how to get to this?
Thank you for any help.
Post by Chris Meyer on May 10, 2022 18:24:17 GMT
My starboard nav light it out. Checked bulbs etc and all ok. Port working fine, so power is getting through. I understand from the electrical schematic diagram there is a Nav Lights Terminal Strip, Im hoping there is a loose connection or something. Does anyone know how to get to this? Thank you for any help. If you have the schematic, does it show a fuse?
Post by carterj22 on May 10, 2022 19:05:47 GMT
There is a fuse back at the main box in the cabin. It looks like the Port side is on the same circuit. It's just finding where this terminal strip is. I think it may need half the forward cabin to be taken out to get to it.. unless anyone know better? Thank you.
Post by buddyseattle on May 20, 2022 23:39:48 GMT
Not sure I can help but here is the diagram showing both lights leading back to a terminal block forward of the tank area. Possibly in the compartment just in front of the V berth cushion. I don't recall seeing it there but since the other light does work, it's not a fuse or breaker issue. Did you check for voltage at the bulb base? Possibly corrosion or something.
Post by carterj22 on May 22, 2022 10:07:05 GMT
Thank you. No voltage at the lights, so hopefully it's the terminal strip. Its just getting to it now.. looks like I've got to take half the forward cabin out to get to.
