Mikeh
Post by Mikeh on Mar 17, 2022 13:02:45 GMT
MF795's mattresses are only 8 cm thick and very hard. After spending more than one night in the boat my hips have started to hurt. To tackle this I ordered a 5 cm thick custom made mattress topper for my MF. Haven't slept on it yet, but it adds 62 % thickness to the mattress and feels very good.
Post by Charlie-Bravo on Mar 18, 2022 19:51:53 GMT
Looks good, I went budget, got a memory foam mattress and cut it to shape with a kitchen knife, and am intending to reshape its cover .... when time allows. But a great comfort improvement on the originals, and a comfy night is worth its weight ..... CB
Post by ihsan on Mar 28, 2022 21:48:35 GMT
Perfect. Do you have the dimensions at hand? An additional comfort tip is to cover the white jell coat on port side plus the triangular one on the starboard with fabric. The fabric is over 2 cm. foam. I did this and the bed feels wider and you can also use it as cushion and recline on it. Also you get some isolation.
Mikeh
Post by Mikeh on Apr 2, 2022 23:13:57 GMT
I have only some rough measures for the topper, like width 180 cm (widest point) and length 167 cm. I just layed the mattress pieces on the floor and cut a template which I sent to the topper manufacturer. As template material I used a sheet of thin and transparent PVC.
