Post by moonshadow on Dec 28, 2021 19:22:58 GMT
I’ve been looking for new seals for the top loading fridge and freezer for my 2014 SO469 without any luck. Tried various online sources and local service guy. I can’t find the model numbers of the units, which would probably help. Thanks. Paul
azmike
Jeanneau Model: 2008 45DS
Yacht Name: Szaffi
Home Port: Preveza
Country: Greece
Post by azmike on Dec 29, 2021 16:49:39 GMT
Paul: Do a search for the post —Freezer door in SO 42DS refrigerator—. I ordered the foam and installed it on my 45DS top freezer door and have no more problems with frost. I did have to remove the old grey factory seal to get a tight seal. good luck, AZMike
Post by moonshadow on Dec 29, 2021 20:16:52 GMT
Thank you for your reply. It sounds like the best option is to try for a Jeanneau replacement part. Then it makes sense to photo and measure the profile and see if they are generally available from another source. The domestic website shows a number of gaskets but requires device model number. I’m making do for now with weatherstrip seals on the surface that the lid closes on. But I suspect the proper seals will work better. Currently in the humid Bahamas I need to defrost about every 8 weeks so it’s tolerable.
Post by mpcsail on Dec 31, 2021 15:20:37 GMT
per jeanneau website for a 53
part 211163 gasket icebox 300L
part 205149 rubber gasket hose ice box doo
these are the only ones i could find
Post by jdl01 on Dec 31, 2021 20:42:34 GMT
As an interim measure, try a closed cell foam outdoor sleeping mat cut to cover the entire countertop area of the fridge. It is non slip and waterproof; a good surface for placing freshly washed dishes. It's insulating properties are good, covers all lid perimeter gaps and we now use it as a permanent fixture in the galley. It's low cost, little work and worth a try.
Post by virtualburton on Jan 3, 2022 20:33:58 GMT
As an interim measure, try a closed cell foam outdoor sleeping mat cut to cover the entire countertop area of the fridge. It is non slip and waterproof; a good surface for placing freshly washed dishes. It's insulating properties are good, covers all lid perimeter gaps and we now use it as a permanent fixture in the galley. It's low cost, little work and worth a try. Cool idea jdl01! Thanks for sharing. D.
Beam Reach State of Mind
Jeanneau Model: 419
Yacht Name: Beam Reach State of Mind
Home Port: Red Bank, NJ
Post by Beam Reach State of Mind on Feb 11, 2022 0:33:07 GMT
I’ve been looking for new seals for the top loading fridge and freezer for my 2014 SO469 without any luck. Tried various online sources and local service guy. I can’t find the model numbers of the units, which would probably help. Thanks. Paul I know I'm late to the party on this, but I just ordered new top & front door seals for the VitroFrigo fridge/freezer. We have model # JN190. Vitrifrigo told me this part will fit these models: BN180/JN190/BN160, and the Part # R117013 GASKET is the same for the top and the front, which seems surprising - I go to the boat at the end of March to see if it fits. You have to order from a dealer, I think there's a list on their website.
Post by moonshadow on Mar 30, 2022 11:52:48 GMT
Thanks for all the tips. I’ll soon be finishing my winter trip amd follow through on the seals.
Jeanneau Model: 419
Post by Beam Reach State of Mind on Apr 13, 2022 15:20:37 GMT
I’ve been looking for new seals for the top loading fridge and freezer for my 2014 SO469 without any luck. Tried various online sources and local service guy. I can’t find the model numbers of the units, which would probably help. Thanks. Paul I know I'm late to the party on this, but I just ordered new top & front door seals for the VitroFrigo fridge/freezer. We have model # JN190. Vitrifrigo told me this part will fit these models: BN180/JN190/BN160, and the Part # R117013 GASKET is the same for the top and the front, which seems surprising - I go to the boat at the end of March to see if it fits. You have to order from a dealer, I think there's a list on their website. I went to the boat and installed the top seal (which was the one that was really in bad shape) without a problem. However, as I suspected the front one was not the same at all. I have a (so far unanswered) email out to Vitrifrigo asking for the correct number.
Post by Elcano on Mar 25, 2024 14:38:41 GMT
Hi, wrote a message over the contact form on the Vitrifrigo webpage. Told them my model (JN190) and got a message back from the country representative in Spain. 32 € plus tax and shipping. Very smooth so far.
Good luck 😉
