Post by mesteve on Sept 23, 2021 21:46:48 GMT
Q: How is your aft head set up to prevent the glass shower door and the metal handle from hitting each other? Ours came from the previous owner with a small parts bag on the handle.
katk
2006 43DS
Post by katk on Sept 25, 2021 22:48:16 GMT
I tried to put a small rubber sticker on the door handle to cushion the blow but it kept slipping off.
Problem solved itself when I added a hook to hold a towel and wet gear the the back of the door- the towel cushioned the doors from hitting each other.
Post by saltymetals on Oct 4, 2021 8:41:56 GMT
I used one of those round soft pads that you put under the feet of chairs to stop them making the floor. I stuck it on the shower door, not on the door handle.
Andrew
Post by alenka on Oct 4, 2021 11:13:30 GMT
As an aside about a year after buying our boat the shower door fell off narrowly missing my toes.
An easy job to re-install in a way that is more secure but I would suggest you check, if you value your toes, the screws for security when you can.
Post by rxc on Oct 28, 2021 16:48:44 GMT
I use a bungee to keep the door from moving.
