Post by mhorvath1218 on Jun 2, 2021 1:27:56 GMT
I’ve been struggling a bit with my anchor and windlass lately and I think my 795 may be missing a roller. Please see the photo below. There is no roller towards the end, but there is holes to mount an additional one. I noticed when I’m pulling up my anchor the line just rubs along the metal frame, which seems like it will chafe the line and weaken it. Am I missing a piece here or is my setup normal? I bought my 2017 795 used last fall, so its been that way since I purchased it. If I am missing one, any recommendations on a replacement? I also just installed a cleat to tie the anchor rode when deployed to relieve stress on the windlass. I put it right in front of the windlass and installed with through bolts and washers, but do you think a backing plate is necessary here? I haven’t used it yet.
Mikeh
Post by Mikeh on Jun 2, 2021 6:26:11 GMT
Hi! It would be very helpful if your uploaded photos were little larger. They appear too tiny at least on my iPad screen to get a picture.
Post by mhorvath1218 on Jun 2, 2021 10:21:39 GMT
I uploaded them full size, just click the photo and it will enlarge
Post by ihsan on Jun 10, 2021 13:17:00 GMT
Post by ihsan on Jun 10, 2021 13:17:38 GMT
Sorry, I tried but I can not open the pictures in my computer. The problem I had with my anchor rollers seems to be different. All together there should be 3 rollers. I changed the first on the tip of the bow, with one that has a channel for the 8 mm. chain. The 12 kg anchor given from the factory when the boat is delivered also glides well in this channel type roller. This way I was able to stop the chain from jumping out from the rollers to the hull. Probably there are other solutions to rectify this problem.
Post by mhorvath1218 on Jun 10, 2021 17:34:48 GMT
So after some searching, I realized I was missing a roller. I’m guessing maybe the previous owner had a different style anchor that did not fit properly with the 3rd roller so it was removed. I just replaced it with a 2.5” lewmar roller yesterday and The anchor sits much higher and more secure now. I think that will solve my issues. Has anyone changed their fluke for a delta anchor on a 795 though? I’m considering it, but am curious how well it would fit and the best size/weight.
Post by csldavidson on Jun 12, 2021 0:27:54 GMT
I've just changed the stock danforth style anchor for a 10kg Rocna, it doesn't sit perfectly, and I was going to see if I could find a large diameter roller for the first one (that you were missing.) My friend has a delta on his 755 and it seems to fit well enough on the stock roller.
Anyone know how/if you can access the back of the four bolts holding the roller in place? Swapping out the assembly would get the best fit. I hope there is a backing plate, etc in there.
I made a bridle with a chain hook to take the weight off the windlass while at anchor.
Post by jnorris on Jun 12, 2021 6:32:06 GMT
I haven’t figured out any access to the backside of the anchor locker or the mounting plate. Would love to know how people have gotten to the inside of that cavity.
