james
Post by james on Apr 29, 2021 11:09:35 GMT
I am hoping someone can provide some assistance here as the dealer has not been very responsive. I bought a 2021 1095 FLY in March and the Genset malfunctioned and is in the process of being serviced via a warranty claim by a master certified marine electrician. That being said the Cooktop and microwave stopped working and it is not related to the breaker/ reset button under the salon dinette table. The ac and outlets all work fine but the microwave and cooktop do not. The electrician and I are looking to know how to lift out the cooktop to access to electrical on at the rear of the microwave to see if there is a fuse or reset back there as well as the same for the cooktop. Does anyone have a schematic or instruction on how to extract the cooktop/ microwave? Any ides on how to fix this issue?
All feedback appreciated!!
Post by stephenm27 on Apr 29, 2021 22:46:12 GMT
The microwave fascia panel is attached via plastic friction clips. If you feel around the edge of the opening, you can locate them with your fingers. Once the fascia is removed, I believe the microwave can easily be removed from its cabinet. From there, you should have access to the bottom of the cooktop.
