Post by romulus on Dec 6, 2020 8:26:21 GMT
Hi. First post. Just joined. Need some advice please. I am a new 1095 owner. Have owned 2 boats previously so used to refuelling. I’m finding the 1095 awkward with issues of fuel spillage from ‘blow back’. I’ve tried filling VERY slowly but irritating with 400 l tanks. Am I missing a trick or is this common?
Otherwise I am LOVING my boat
thanks
glyn
tednc1095
Jeanneau Model: NC 1095 (2019)
Home Port: Tampa, FL
Post by tednc1095 on Dec 8, 2020 3:10:20 GMT
This is a common problem with the fill ports of the nc1095. I have a 2019 model, and the dealership had to replace both fill ports, so the fuel inlet gases are vented directly out of the fill port. (not the little vent above the gas cap) I hope this make sense. Tell your dealership about the problem. I'm sure they've had to deal with this issue....it's a common problem, and covered under warranty. Otherwise, congrats....it's a GREAT boat!
-Ted
Post by romulus on Dec 8, 2020 19:25:56 GMT
Thanks. Very very helpful.
Post by carlthomas on Dec 10, 2020 22:01:00 GMT
This is a common problem with the fill ports of the nc1095. I have a 2019 model, and the dealership had to replace both fill ports, so the fuel inlet gases are vented directly out of the fill port. (not the little vent above the gas cap) I hope this make sense. Tell your dealership about the problem. I'm sure they've had to deal with this issue....it's a common problem, and covered under warranty. Otherwise, congrats....it's a GREAT boat! -Ted That’s nice to know, we took delivery of our 1095 in July (first boat) and I had this happen to me when I filled up a couple of weeks ago, It caught me completely by surprise and I got covered in petrol. At the time I thought I might not have been paying attention and not had the fuel nozel in properly. I’ll raise with my dealer and see what they say. Regards Carl
Post by romulus on Dec 11, 2020 22:02:45 GMT
Update. Problem removed by dealer. Something to do with a regulator valve for European regulation which has now been removed under warranty. It was the posts on this board that alerted me to the fact that it wasn’t my technique.
Haven’t filled yet but dealer discussed with Jeanneau and identified the issue.
Hopefully no more gasoline showers. I’ll let you know.
thanks again for the input. So helpful
Post by Don Reaves on Dec 12, 2020 0:05:25 GMT
I'm very glad to hear you found a solution for this problem. This past summer, I helped deliver an Albin 36 trawler through the Great Lakes, and it had this problem in spades. I filled the two tanks, more than a hundred gallons of diesel each. The first kicked back repeatedly, and we probably spilled a pint of fuel into the canal. I reduced the flow for the second tank, and it took about 30 minutes to fill. But it only kicked back once, and I managed to catch the spill with a handful of paper towels.
I'm so glad this never happens on my sailboat. It shouldn't happen to anyone.
