Post by westboating on Oct 12, 2020 18:58:58 GMT
Folks,
I have an 895 with a moist aft locker. I can't keep it dry back there. Has anyone figured a hack out to keep the moisture down in that area?
Thank you
Post by fritz on Oct 12, 2020 20:37:29 GMT
The locking mechanism on my 795 leaks water.
Post by lynnardm on Oct 13, 2020 14:11:46 GMT
See the post “NC and Merry Fisher Dry Hulls”. In the case of the cockpit floor door latches, it’s either coming thru the screws or between the surface of the door and the top surface of the lock. I’d start with the screws. Remove each one and apply new sealant under the screw heads then reinstall.
Capt’n Lynn
Post by fritz on Oct 13, 2020 14:36:27 GMT
Thanks, Capt’n Lynn!
