Post by Gio on Aug 16, 2020 9:59:28 GMT
Hi all,
I just wanted to confirm with you all if in your pre-rigged configuration for dual engines boat you got only 2 batteries (1 house&start + 1 start).
Engines in the most recent digital versions requires a dedicated starting battery per each engine, I want to check if in different markets/geographies Jeanneau provides such option or just the house + start only.
Thanks
Post by nc on Aug 17, 2020 0:19:25 GMT
On a 2021_500hp_ V8_Sport, 2 AGM batteries for engines, 1 for house all 3 in the storage between fuel tanks and 1 under the saloon's bed for bowthruster
Post by CruisingCascadia on Aug 17, 2020 3:17:38 GMT
Our 2019 nc895 offshore was originally wired with one bow thruster under the master bed, one house/start and one start in the aft hatch. This was how our 2017 855 was wired too and the fridge killed the house/start battery on one of our first trips. We now have 4 house 2 start in the aft and one thruster battery in the front.
Post by Gio on Aug 17, 2020 10:53:34 GMT
Thanks all-
I haven't mentioned the battery for the bow thruster, but I kept this out of the equation as it is not part of engine/house system.
My 895 sport/marlin 2020 model (dual engines offshore) only got the 1 starter + 1 house+starter, and it is completely wrong for this config - I already knew I had to change this but i find not right that the dealer/manufacturer does not specify this and not offer different setups. I asked before purchasing the owners' manual and that one was the config there.
I hope they have rectified this for 2021 editions, if not, i recommend the prospective owners choosing a dual engine config, to upgrade the system in case they still offer the house+start shared battery.
Post by nc on Aug 17, 2020 20:58:43 GMT
They changed it for 2020, in the aft hatch 2 engines batteries and 1 house and 1 for bowthruster in the saloon.
Post by Gio on Aug 18, 2020 5:38:49 GMT
They changed it for 2020, in the aft hatch 2 engines batteries and 1 house and 1 for bowthruster in the saloon. Yes - clear. That config was not available when i ordered mine in early 2019. Will do the modification (easy job) and i am working on upgrading the house battery too. I will post soon.
