lesknowles
Wanted Jeanneau 35 or 36i shoal draft (1.45 ) owners version
Post by lesknowles on Dec 9, 2019 20:24:19 GMT
I have so 35 with port side leaking windows.What sealant should I use to replace the small bead of sealant around the outside edge of the windows.
Regards Les Knowles
Post by Tafika II on Dec 9, 2019 20:28:11 GMT
Hi Les, Depending on the severity of the leaks, here a link we posted in Hints & Tip on what we did and what we used. As of now, there still or no leaks. link
Post by ianqv on Dec 17, 2019 12:09:01 GMT
As Tafika says..... there is an excellant "how to" do this in the hints and tips section. I recently followed the direction given (on my S/O 37) and they have been dry ever since! Also you would NEVER know that the windows have been re-sealed.
Ian
