Post by svcoder on Sept 23, 2019 12:25:23 GMT
Not the most professional install but it works. This is a 16.5 x 16.5 8lb. Giantex auto washing machine. 35lbs and held in compression by 2 x 44lb/inch foam pads on each side, it's going nowhere. Uses 250W when washing and between 13 and 20 gallons a wash. Clothes are spun at 1600rpm photos.app.goo.gl/djP95Av8K3PuEiN26
Post by ianqv on Oct 7, 2019 11:24:41 GMT
Not the most professional install but it works. This is a 16.5 x 16.5 8lb. Giantex auto washing machine. 35lbs and held in compression by 2 x 44lb/inch foam pads on each side, it's going nowhere. Uses 250W when washing and between 13 and 20 gallons a wash. Clothes are spun at 1600rpm photos.app.goo.gl/djP95Av8K3PuEiN26Thats looks great for extended cruising! What make and model is the washer? Cheers Ian
Bijoux
Jeanneau Model: 49 DS
Home Port: Detroit, MI USA
Post by Bijoux on Oct 7, 2019 18:06:18 GMT
Not the most professional install but it works. This is a 16.5 x 16.5 8lb. Giantex auto washing machine. 35lbs and held in compression by 2 x 44lb/inch foam pads on each side, it's going nowhere. Uses 250W when washing and between 13 and 20 gallons a wash. Clothes are spun at 1600rpm photos.app.goo.gl/djP95Av8K3PuEiN26Could you provide some pictures and details on how you connect it to your hot/cold water supply? Looks like you just set it up in the bathroom?
Post by svcoder on Oct 11, 2019 11:11:33 GMT
There are pictures in the google photos link. It's a Giantex fully automatic washing machine which I ordered from Amazon for 210 dollars or so. It's got a single cold water inlet which I made an adapter pipe to connect to the shower hose. I just run cold water through it but you could run warm water in by using the normal shower knob to adjust the temperature. It's setup in the main cabin bathroom. I used foam squares to secure it, 44lbs of pressure per inch of foam. Washing machine: www.amazon.com/dp/B07S39CW8Q/ref=cm_sw_em_r_mt_dp_U_7lgODbWHY0C7DFoam to secure it: www.amazon.com/dp/B07WNZZGTM/ref=cm_sw_em_r_mt_dp_U_XmgODbZH47E6WThe adapter water hose is just a visit to lowes for parts.
