Fans
Aug 23, 2019 22:05:38 GMT
Post by voiceman1uk on Aug 23, 2019 22:05:38 GMT
Hi all
has anyone fitted interior fans and if so which ones did you use
thanks
Paul
Fans
Aug 24, 2019 6:19:25 GMT
Post by Zanshin on Aug 24, 2019 6:19:25 GMT
I have always added fans to my boats. In previous ones I had 2-speed Hella ones and currently I have the Caframo 3-speed fans which I like very much. They see a lot of use and my only gripe is that they are somewhat difficult to clean. www.amazon.com/Caframo-Bora-12V-Marine-Speed/dp/B00S15WGAI
Fans
Aug 24, 2019 8:36:19 GMT
Post by alenka on Aug 24, 2019 8:36:19 GMT
Fans in the Med are a must, unless you really like hot and sticky cabins.
Sorry I cannot remember the make of ours. Bought in Greece from the chandlers.
Look for those you can swivel and tilt with a good locking mechanism to hold them in place once adjusted. Try to mount them to a solid surface rather than a infill panel as they can sometime set up a resonance on the latter. However, we find those that make a little noise help to drown out late night noise from the quayside and, believe it or not, are are better to sleep with.
We have two fans in our aft cabin, one for each side of the bed. In practise we have found the opposite fan gives a more pleasant feel than the nearest giving a direct blast onto you.
Ditto to cleaning them. They are a pain.
Fans
Aug 24, 2019 17:52:10 GMT
via mobile
Post by moonshadow on Aug 24, 2019 17:52:10 GMT
Carfano fans mounted at places where I can easily access 12 volt wiring.
Fans
Aug 24, 2019 18:28:36 GMT
Post by heatherina on Aug 24, 2019 18:28:36 GMT
We fitted a Caframo Sirocco II in the aft cabin. Quiet and plenty of air flow.
Fans
Aug 24, 2019 22:16:59 GMT
Post by sitara on Aug 24, 2019 22:16:59 GMT
Paul you may have 12 volt wiring already in place that can power the fans. There is additional wiring in the loom on my SO36i that is not connected to anything. Check your wiring diagram.
Fans
Aug 25, 2019 8:41:20 GMT
Post by voiceman1uk on Aug 25, 2019 8:41:20 GMT
Hi
Yes the wiring is already in place so should be a simple upgrade but just looking for advice on choice of fans..
thanks all
Paul
Fans
Aug 25, 2019 13:53:11 GMT
Post by Zanshin on Aug 25, 2019 13:53:11 GMT
I would recommend not going for a no-name cheap fan unless you can see (and hear) it first. Every decibel that you save will be worth every penny that it might cost extra.
Fans
Aug 26, 2019 7:40:55 GMT
Post by voiceman1uk on Aug 26, 2019 7:40:55 GMT
Thanks yes that is the current problem...I have some very cheap eBay specials which whilst do the job of moving air are very noisy
thanks again all
Paul
Fans
Aug 26, 2019 14:34:30 GMT
Post by MalcolmP on Aug 26, 2019 14:34:30 GMT
As Alenka correctly mentions, the fixing is also critical, we have both a Hella in the guest cabin and 2 Caframo Ultimates in our cabin, which I like as they are easy to clean. www.marinesuperstore.com/hatches/fans-windscoops/caframo-ultimate-fan?variant=99052331but I took the, at the time, easy way of fixing them to a thin ply panel, which can get bad vibrations. I have improved things slightly with foam packing, but now don't really want to move them to a hard surface due to the extra holes...
