Post by Bora on May 22, 2019 11:28:27 GMT
Has anyone with a 469 or similar managed to fit a larger bilge pump into the well? I'm thinking to maybe raise the mounting platform to allow a larger pump.
Post by moonshadow on May 22, 2019 12:00:59 GMT
I’m following this also. I would like to get rid of the 1100A automatic pump and place a float switch the automatic pump water sensor seems to be a continuous problem. I am hoping that a float switch in the small pump well area will be a better solution. But I hear that the float switches tend to fail also. Any better ideas?
Post by Bora on May 22, 2019 12:14:07 GMT
my bilge pump continuously runs at a very slow speed when in automatic mode but will ramp the speed up if i pour some water into the bilge, that's whats prompted me to look in to a replacement.
The 2000gph rule mate bilge pump needs to have an external float switch so it could be an option, just need to make sure it can all be removed easily if you do need to replace the float switch.
