Post by moonshadow on Jan 20, 2019 22:14:17 GMT
The only non-LED light on my boat seems to be the down facing spreader light for illuminating the foredeck. I’m alone on the boat right now and can’t get up the mast to look at the type/size. Does anyone know the spec so I can order an LED replacement for a friend to bring down? I’m hoping that it is some standard PAR bulb that can easily be replaced by LED. Thanks
Post by moonshadow on Jan 20, 2019 22:18:32 GMT
I left info out: 2014 SO469 is the boat
Post by neworca1 on Jan 21, 2019 2:10:58 GMT
I had our rigger replace ours with an LED...I've just sent her an email to ask what she used. I'll let you know as soon as I hear. Cheers.
Post by neworca1 on Jan 21, 2019 19:15:10 GMT
This is the one. Great bulb!
Vstar LED PAR36 12V 9W 3000K Bulb,950 LM,With Lenses,High Concentration,Super Bright LED PAR36 BULB (9W)
Post by moonshadow on Jan 21, 2019 21:16:04 GMT
Thanks. I was hoping that a par spec would fit! Time for a quick upgrade.
ricardo
Jeanneau Model: Jeanneau 57
Yacht Name: SHINING GIRL
Home Port: Providence, RI
Post by ricardo on Jan 31, 2019 14:50:53 GMT
I just replaced mine on J57 with the original equipment replacement: www.optolamp.com.br/english/index.php/produtos/marine-led-lighting-interior-lights/item/113-spreader-led-light-500-plus.htmlThe dealer was NAUTOS USA. Note that the voltage spec by the manufacturer is 10-30V. Some of the distributers say it is 10-15V, but they are wrong as far as I can tell. Why would a small manufacturer create a second part with a narrower voltage spec- makes no sense. I ordered anyway and sure enough they showed up 10-30V. I replaced the units, but they did not work. There was no relay installed (ETA TR 200 ...) No spare, but a swap lit them up just fine. Now I'm trying to source that relay with no luck so far.
